Rim Question
I have a set of 16" steel rims that came off of a '98 z-71. They have LT 265/75 16 Mud Tires on them. Will these fit on a '02 Z-71. My factory rims have the same 6 lug pattern. Do the lug nuts that hold my current rims on now work with the older rims? Any help is appreciated. Thanks and Merry Christams.
yes they will fit, I'm running the same size of rims and tire on the exact same truck as yours (OEM Wilderness AT and rims). Trying to save some cash to move up a little next time around.
Merry Christmas
OBS steel wheels will not fit on my '02 Silverado, the rear brake caliper wouldnt allow them to fit even thought the lugs lined up. The wheels I tried were from '95 C/K. I didnt think they changed them from '95 to '98 but daxrizo says he is runnin them on a NBS, and I dont see how. Maybe his brake caliper is smaller???? You should just try a rear first to see if they fit, then try a front. I didnt even get to try one on the front when I found out the rear wouldnt fit!
I just went back out to check and they are the ones I spoke about......maybe I was fooled at purchase, I did get it second-hand. :thumbs:
