What subwoofers are you guys running in your standard cabs? I want to keep my seat back with nothing modified.  I've theJL audio 13tw5 but I'm not sure if a box can be built to fit.
  • 3 months later...
    Gkistler
    Gkistler
  • Who's Online   6 Members, 0 Anonymous, 921 Guests (See full list)
