Rear end squeak in reverse
over the weekend, my truck started a really loud squeak when i am backing up. it seems to be coming from the back end. I tried touching the brakes while i was moving and it had no effect on stopping the squeak, so its not brakes rubbing. it goes away when i put it into drive. any thoughts??
Each driveshaft has two u-joints but you're likely only having trouble with the ones in your rear driveshaft. I actually have no idea why it only does it in reverse, but that's what happened with my truck. It squeaked in reverse for awhile and then migrated to forward as well. My factory units in the Sierra went at around 60,000 miles.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
