  • 1 month later...
They should, they worked on my 1500 leveled truck. I'm buying a set for my 3500 now too but its not leveled.
    Policeoff01
    Policeoff01
  • Who's Online   4 Members, 1 Anonymous, 745 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
