Only on cold weather starts engine has a clatter for bout 10 or so sec then goes away.
ive been thinking it was lifters but I’m not 100% sure yet ?
does anyone know what causes this ?
Thanks in advance ,,,,,,Doug
Edited by 333Fitter
intake manifold gasket leak. Cold Start Sensor going bad. Varnished throttle body butterfly. Fuel injector fouled.  Way too many things.  Oscilloscope, 10k computer. jmho.
What's a cold start sensor? Are you sure you know what you're talking about here with LS engines?
A video of the issue would be more helpful.
Having lifter clatter isn't uncommon and same goes for piston slap. Both happen on cold engines. Even seen broken exhaust manifold bolts cause cold start noise that quickly goes away as the exhaust warms up.
Mine did this with plain Mobil One oil and doesn't do anymore since I started using ACDelco's oil, same weight, both full synthetic.
On 8/25/2021 at 8:35 PM, 333Fitter said:
You mean Dexos oil right ?
I’ll look at that next time I change oil.
thank you ,,,,
New Engine Oil and Oil Pressure | Chevy Tahoe Forum | GMC ...
    ar0517
    ar0517
  • Who's Online   5 Members, 2 Anonymous, 468 Guests (See full list)
