Happy Holidays
:nono: Greetings everyone, just wanted to wish you all a safe and happy Christmas and New Years. At this time of the year for being greatful, one thing I am most greatful for is the friends I have made on here and the great advice I get. This is one of the best Forum sites I have been to. Wish my old stomping grounds over at CrownVic.net were as nice as you guys, but sadly that place is full of alot of terds who can't act like mature adults. :rolleyes: They put people down left and right and use a ton of foul language which I strongly believe has no place on a public message board. Thanks again for the great website here and the nice people who post here and run things. :cheers:
Merry Christmas everyone. Hope Santa brings you all what you wished for. Also want to thank everyone for their great advice and honest opinions. Hope everyone has a safe holidays and remember.......Be especially safe on New Year's eve. Well, I'm off to look under the tree for my Trenz billet grill. woohooo!!!! :cheers:
