13574802 kit fits 2018 Escalade. Will it fit Silverado? Probably. Cheap enough to try.
A little more digging into this and found the GM PN for the K2 SUV door strikers below....looks like the K2 SUVs use a different striker than the K2 Pickups??  That seems dumb unless the SUV version is somehow made to accept this cover plate.  Wonder if all K2 SUVs get the cover plate from the factory?
    Gkistler
    Gkistler
  • Who's Online   4 Members, 0 Anonymous, 877 Guests (See full list)
