I am unable to get either key fob to lock/unlock truck. The panic button does not work either. I have replaced batteries in the fobs and cleaned (with isopropyl alcohol on cotton swab) the connections on the wafer board. All fuses appear to be working. I did not use a tester on any of the fuses; I eyeballed it. The only thing I can think is that the remote keyless receiver is not working properly or at all. Does anyone have insight into this particular problem?
Edited by Wasted Ute
Additional info inserted
Who do you know with a Tech-2 or other bi-directional scan tool that can read BCM codes and test out the receiver?  If it is not working, there will be internal codes as to why.  On my type and generation truck, this information is in the Remote Control Door Lock Receiver RCDLR.  A new one has to be programmed to the truck.
Thanks for the reply. I took the truck in last week to have the TPMS checked and/or replaced. Dealership said they couldn't reset TPMS, they were unable. I left, scratching my head in confusion. I figured a dealership would be able to get to the bottom of something like my problem.
I got home and searched YouTube video, some were very helpful. I changed battery in key fob, I cleaned the circuit board in fob with cotton swab and isopropyl alcohol. I couldn't get key fob to lock/unlock doors, etc. Some of the YouTube video suggested that key fob is integral to resetting TPMS. Maybe the fobs (I have 2) are both bad?
I am attempting to narrow down the problem because I have lost faith in the dealership. This is a 2012 GMC Canyon. I do not have a Tech 2 or similar tool.
Key fob does not activate the tire learn mode for the TPMS on that generation Colorado.
To activate TPMS learn:
- Ignition to ON
- Set the parking brake (at a minimum, just enough to trigger the park brake light on).
- Take the headlight switch and quickly within 3-5 seconds turn the switch to the PARK lamp position 4 TIMES in a row.
- Once you do that the horn with DOUBLE CHIRP, acknowledging its in TPMS learn mode.
- With a TPMS relearn tool (EL-50448 or equivalent from Amazon, etc.) start with the LF sensor and activate it.  The horn will sound when the sensor is learned to the truck.
- Continue around to each sensor CLOCKWISE (LF, RF, RR, LR).  Once the LR sensor learns, you will get one horn followed by a double horn confirming the end of TPMS learning.
Tire shops might have an OBDII style learn tool which would have no need to activate the truck's TPMS learn mode.  Those tools use the OBDII port to transmit the TPM sensor data to the vehicle.
Back to the fobs.
On the 05-12 Colorado, the BODY CONTROL MODULE is the brains/receiver for the TPMS as well as the keyless entry.
Is your tire light on at the moment?  Service TPM?
If its not, would get a hold of one of the TPMS learn tools, and follow the learn procedure I posted.  If it goes into learn mode and the sensors learn, that would tell me the antenna in the BCM for the tires/key fobs is working.
I'm sorry it took me so long to reply. I had not checked this forum as I had been busy with work since last posting.
I need to get ahold of a TPMS learn tool before I can test out your solution. I can tell you that the TIRE LOW SERVICE TPM is on. This has been on for months and is the whole reason for my post. I took the truck to Autozone; asked them to connect their computer to it & get me an error code. No error code was shown. Thank you for replying with steps for a solution. I will post an update soon, I hope. Or soon after the holidays.
Amazon.com: VXDAS TPMS Relearn Tool for GM Tire Sensor TPMS Reset Tool Tire Pressure Monitor System Activation Tool OEC-T5 for GM Buick/Chevy/Cadillac Series Vehicles 2021 Edition : Automotive
As far as reading codes, most of the little handhelds that parts stores have can't read anything other than ECM/PCM/TCM codes, sometimes ABS and Airbag.
Something like this:  BlueDriver   Can let you scan and read codes for all modules as it supports enhanced diagnostics to read codes in all available vehicle modules it can read.
Edited by newdude
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   0 Members, 0 Anonymous, 572 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
