1999 Silverado 1500, 5.3 iron block (LM7)
Completely stock other than cat delete
I know it’s a bit much to ask an old truck to run in this kind of weather but I don’t have much choice unfortunately. Drive to work is mostly highway or gravel road driving. Every year when the cold snap hits (-40° range), my truck will, I assume, run rich (can smell fuel in exhaust and fuel consumption goes thru the roof on a 15min drive) and will eventually choke on itself and die, even while driving 80-100km/h. I have a winterfront on, have replaced MAF sensor, wondering what to try next. Truck runs perfect any other time.
A smoke inspection of your vacuum lines will rule those out.  Cleaning the Tb and Map sensor when you can can help.  Also if its been a while, go ahead and change your coolant sensor, being sure not to get any antifreeze on the connections. Using tape on the new parts connection until after it is in will help.
    ballencd
    ballencd
  • Who's Online   3 Members, 0 Anonymous, 455 Guests (See full list)
