Hey everyone I'm sure this has been asked before but I'm new here and don't quite know how to navigate the site yet
I'm looking at running pacesetter long-tube headers but I want to keep the two original cats on both sides of the cylinder banks the third one will be left out
My goal is to run a true dual system with an x-pipe to equalize the pressure(of course) an exhaust cutout and then two rear fenderwell dumps
I'm concerned about the ECU throwing the dreaded o2 sensor code or other issues/Hazzards I might run into
also looking for everyone here's suggestions on pretty much anything exhaust related or just information in general about these trucks since the whole thing is relatively new to me
Thank you!
If you cut the factory cats out and have them welded into the new exhaust it should be just fine as far as the emissions go.  You'll just need to weld o2 sensor bungs into the exhaust for the rear sensors and keep them as close to the rear of the cat for placement.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 507 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
