2020 3.0 dmax with 38k threw p1339 yesterday. No ill effect other than disabling the remote start while cel is on.
seems to point to glow plug error. No trouble cold starting even down to 0*.
Dealership didn’t have an appointment till the 25. Will update after.
Well that was an easy fix, if it took care of it for you. Thanks for the update.
My 2020 with 95K miles had same issue BUT I also noticed the DEF gauge wasn't correct after filling the tank it remained at less than half, as the DEF tank fuel diminished the check engine light would come on again. After driving for about 50 miles it would go off, took to preferred Diesel  shop I was told that my issue was the computer needed an update. After 465.00 dollars later and driving less than 50 miles the light came back on. I'm pretty sure its my Glow Plugs and Def Tank, truck goes back first thing in the morning hopefully they can figure this thing out.
2020 3.0 duramax...80k...only 3 are mine sofar.....started throwing 3196 coolant code.....just after purchase....dealer had put in new batt.. brakes ..general service....so i figured it was just getting used to a new driver....stayed off for a while....now 3k later....has tossed it again...now with the 1339 glow plug code....dealer has reset ..cupple times....tranny has been updated ...for the recall.....dealer now put me on the appointment schedule...3 to 4 weeks.... got my own code reader ...will continue to reset so i can remote start....its cold here in ct....
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,253 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
