Radio has a mindset of it's own,  left side of screen won't work, changes channels out of the blue, can't set clock, screen only shows set language, one issue after another.
Welcome to the site.
How about a little more info on the truck, and which radio you have?
Without really any history/information, my guess would be failing HMI module.
