This is my last resort, I’ve searched all over the internet. My 2000 Silverado with the 5.3 has a high idle problem, it idles at 1000 rpm constantly. It only idles normally when my ac compressor is actively running. I have replaced everything, intake gaskets, idle air control valve, throttle position sensor, MAF. Have tried to find vacuum leaks but they aren’t any. If anyone has ever had this problem please help me solve the issue. I’d really prefer not to have my ac compressor turned on because my evap core drain is clogged and it leaks into my floor on the passenger side.
If you unhook the throttle cable does it still have a high idle?
If it does then it has to be a vacuum leak or the throttle blade screw needs adjustment. Typically the blade adjustment is a last resort type thing.
A vacuum leak would also show very high fuel trims too on a live data scan tool.
Unhooked the throttle cable and the cruise control cable. Still idles high. When I start the truck is idles down the idles right back up
What brand of IAC did you install, just curious?
Are you able to watch fuel trims on a scanner too?
It was a Duralast gold IAC, two of them because I assumed I might have gotten a faulty part the first time. I do not have a live data scanner but when I do get ahold of one what should I be looking for?
also I’m very tempted to turn that idle screw one turn. There is 1 thread of shiny above the threads where it looks like it might’ve been turned before I bought the truck, maybe the previous owner turned trying to compensate for the bad iac?
Edited by BecauseAmerica1
You'd be looking at the long term fuel trims, if they were stuck up around 16% there would be a vacuum leak. But if the leak was that bad to cause the idle to be higher then it would already be spitting codes for a lean problem.
I'd try slowly turning the idle screw to see where that gets you. A warm idle should be around 550 rpm but anywhere close to that is fine so long as it doesn't stall at idle or when coming back down to idle.
    C. Hart
    C. Hart
  • Who's Online   4 Members, 0 Anonymous, 511 Guests (See full list)
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
