Bought a rebuilt 2015 Chevy Silverado. Have a few electrical gremlins that are all pointed to a bad BCM:
1. Electric door locks don't work (solenoids are brand new and test fine.)
2. Dome lights don't work
3. Rear right brake lights don't work (new bulbs, new wiring harness.)
4. Center jump-seat cigarette lighter has no power (now power to Accessory fuse in right fuse panel.)
So my first question, does anyone know who can repair my BCM? Or do I need to just buy a new one?
Separate, but related:
I removed the bone-stock I03 radio and installed an Alpine iLX-F411 with a Maestro module. Added a factory tailgate handle backup camera (it even works!) I also swapped the rubber work-truck steering wheel with a leather steering wheel with the added radio control buttons.
Is it even possible to reprogram the BCM (my current or a new one) to add the steering wheel buttons? Truck does not have the HMI module.
The dealer is about the only to program a BCM for you, with that they are vin tied to your vin for the firmware. You wont be able to add on any other features or options other than what your truck came with from the factory.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
