I’d like to level up my ‘21 4x4 Silverado LT. I’ve seen both leveling blocks and leveling shocks. I’m leaning towards the blocks. What has been your experiences been? Pro and con.
The search function is your friend, especially with a topic that is exhaustively covered every other day to the point where people don't bother responding to new posts inquiring about the aforementioned topic.
A quick search resulted in the following.
