I had a collapsed lifter and I had them replaced on the passenger side of the engine. Now after getting the truck back I have code P0430 (bank 2 cat deficiency). Is there a chance that the cat just needs to burn off any coolant that might have been spilled into the exhaust when the head was pulled or do you think the actual Cat converter is now bad?  Tips on how to tackle it? I will take off the o2 sensors on bank 2 and inspect them before anything else.  I already checked voltage to and resistance on the sensors and both of those check out.
I know wiring and resistance checked OK but you able to swap post cat sensors between banks? If the fault goes to 1, sensors reading incorrectly. Stays in 2, further diagnose.
I swapped the downstream o2 sensors last night and went on a 15 min drive on the highway, as soon as I let off to exit the CEL came back on.   Same P0430 for bank 2 so the sensors aren't the problem.  I'm sure the catalytic converter for bank 2 is bad.   Pics of o2 sensors below, I noticed the bank 2 sensor was cleaner than the bank 1 which I though was odd.
Bank 1 left vs bank 2 on right
0?ui=2&ik=99501e1575&attid=0.1.1&permmsgid=msg-f:1728192835765402969&th=17fbc63a4f2bfd59&view=fimg&fur=ip&sz=s0-l75-ft&attbid=ANGjdJ-3pUHrcKkofyqJ5rpimbauGcIERG5B8Fmhmol-bPHlgQb9xAOlwHj7kn_t68kcXmdtLxV1_cKigHwq0HaeqANv76D5XzPvemeZDNS4iSCgJQ8vKuwmnLvPvPQ&disp=emb
0?ui=2&ik=99501e1575&attid=0.1.1&permmsgid=msg-f:1728192817908692917&th=17fbc63626d437b5&view=fimg&fur=ip&sz=s0-l75-ft&attbid=ANGjdJ8TKulSkIxB4x-JDH3uj8sjhudl9ebOg15SQn02ALbKT4dNB3HLuorbIDJufm_q3G3VbAR-JvFUM99NnZIskxgV2UGxZdXcWm6nwXloQfNK5NBj1u5P_7fAUGI&disp=emb
Thoughts on replacement options?
I found a set that was supposedly removed at 9k miles from a 2018 to be replaced with long tube headers.  How would I check them visually to verify?  Do I remove mine and inspect before I purchase anything?
Thanks for the input.
IMO, Only thing would be to check the monolith / cone for proper honeycomb without much wear or clogging.
Have you yet tried doing a hot run / cat burn off procedure? Everytime I do a seafoam procedure, I follow it with a high RPM run on the freeway for 10/15min. Drop down the gears, get the RPMs high and cruise on the freeway for a while.
I forgot to mention, after the drive, I used an infrared gun to check the temperatures of the cats while it was still on, bank 1 cat was at ~210 degrees and bank 2 at ~250 degrees.
OEM Cats are on back order with no eta from GM.  Any recommendations on aftermarket that will work like oem and keep the CEL off?  Magnaflow cats a good option?
Space the rear o2 sensor out of the exhaust stream a little bit, that is an easy thing to try to see if the code will go away. I call it the spark plug non-fouler trick, those are the same thread as a oxygen sensor. You can google/youtube video's on what to do, only cost you a few bucks to try.
  • 11 months later...
On 3/7/2023 at 10:10 PM, OscarEChavez said:
did you ever figure out the issue? i’m having the same problem now
Yes, One Catalytic converter was clogged.  Had to replace the Y-Pipe. Luckily I found someone local who had a y-pipe with both cats with 9k miles on them so I swapped those in. No problem since.
Mind if I ask how much you paid for the Y pipe.  I have one under the house I could let go since the way my exhaust is now.  It can never go back on this truck.
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 3,061 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
