Hi y’all first time poster. I just bought a 2021 Chevy LTZ Texas edition and it has the LED housing for the low beams. How do I upgrade this. The light output isn’t optimal for what I want can you upgrade these cause unlike the halogen housing. I can’t find anything that will allow me to.
If I’m just stupid. Please tell me.
Well it’s not as simple as just replacing bulbs since they are not replaceable like you may be used to (or like the low trim level halogen bulb housings).
You only have a couple of options:
-Get lights (whole headlight housings) from a high country. They are a “better” high intensity led light.
-Find an aftermarket solution like a complete replacement housing or a retrofit of the OEM housing. I don’t know what’s out there for this, if anything.
-Add some auxiliary lighting.
I found my stock lights good on my '19 RST.  I do love my '22 LTZ refresh lights and glad the went back to projectors on the low beam.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 703 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
