Hello! I have a 2019 GMC Sierra 2500HD SLT with chrome bumpers and looking for someone down to swap with a set of Summit White painted ones. Mine has sensors. LOCATED IN SHINGLE SPRINGS, CA. (Near Sacramento).
FRONT: needs to be a 2015-2019 GMC Sierra 2500 with sensors.
REAR: can be a 2014-2018 Silverado or GMC 1500, or a 2015-2019 Silverado or Sierra, with sensors.
Thank you!
