Hello everyone,  I bought a Denali 1500 brand spanking new in 2015. Since then I've had issue after issue and even ended up with a brand new engine with 25k miles.
Since the engine was replaced or maybe once before i have noticed a vibration that seems to be when I accelerate and feel like i am driving on rumble strips. It has been happening on and off for a month now. (No worse no better than the day before)
This issue has been fixed by the dealership at the least 3 times and hell maybe 4. I have looked through all the service paperwork and cant find the information on what was fixed. I have contacted the dealership and they are saying that they have absolutely no information on what was fixed/replaced/  i want to say that they told me once that something was reset!!
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
