Does anyone know if 1/4 wheel spacers are needed for UCA clearance with 285/65R20s on factory wheels? Got tires ordered and would prefer to order the spacers now if I'm going to need them.
Thanks,
Casey
They’ll fit, without needing the spacers. I have 285/65 on the stock wheel, slight rub at full lock in reverse. Progressively has been less rub as tires start to wear down. Ridge Grapplers. Hope it helps.
Edited by Trapusouras Rex
Thanks Rex!
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,035 Guests (See full list)
