Hi guys I was wondering if you would have some insight into an issue I am facing with my 1500 Silverado Crew Cab 4wd 5.3L. The other day I was moving and I was towing a trailer with probably 4000lbs I would estimate. It was 105 outside and going down the highway at about 70mph my truck started to get pretty hot at probably 235. I turned my heater on as well as slowed down and I was able to finish off the day. I just figured that it was a hot day and I was pushing hard and didn't think much of it. No problems since until a day ago where I was hauling a fridge and some other stuff in the back on the highway and I began to overheat again. Same thing as last time but what is concerning me is that I wasn't moving that much weight this time and I began to overheat again. It was another hot 105 degree day and I am not sure whether its just because its hot out or something is wrong. Coolant is topped off, and my radiator looks like it could use a cleaning but it doesn't look all that dirty. Also I only overheated on the highway, slowing down driving in town was fine and even idling was fine, it was only highway speeds. Anybody got any ideas?
TLDR:
Truck is overheating at highway speeds only and only when towing at least a couple hundred pounds of weight. Idling and driving in town is fine.
Has the cooling system been drained, flushed and refilled? Clean the radiator. Thats where  I would start.
Less than a year ago it was. Yeah that’s what I’m currently planning to do.
Forgot about this thread. I ended up taking out my grille and deep cleaning my radiator, transmission radiator, and condenser. It seems to have helped greatly with heat. I haven’t towing anything that heavy for that long as of recently but it seems to have at least helped if not fixed the problem. I had a bunch of bent fins so I fixed that and installed a bug screen inside the grille to protect it in the future. Thanks!
I had a similar issue years ago on an S10 Blazer.  Lots of dead plant debris had made it up between the condenser and radiator and I couldn't see it without taking off the condenser.
I would make sure cooling fans are running on low and high speeds. Also, I think stye should kick on high when the AC is on.
    tararebecca
    tararebecca
  • Who's Online   2 Members, 1 Anonymous, 521 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
