2015 suburban - backup camera - service rear vision system message and the screen shows the area behind the vehicle but very dark screen and difficult to make out objects.  I replaced the camera and get
the same error
I just bought a new-to-me 2015 Sierra High Country 2500 and the backup camera image is quite dim compared to my prior 2015 Silverado 1500. I don't get the "service" message you are seeing but did the new camera address the dark image you were seeing?
  • 3 weeks later...
the same error
What were the OBDII codes?
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 674 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
