you guys with lifts...
My friend is about to get the pro comp 6'' on his 02 ecsb z71. When we were talking about what size wheels to get, I suggested 16x10 as I figured most people would. But he told me that the shop said 16x10 would not fit and he could only go with 16x8. He wants a wider stance than stock but nothing overkill. So I told him just make sure the offset is not too much. He said the guy at the shop was explaining the difference in lifts and that some have an end result of a wider stance than others regaurdless of wheel width and offset. I did not know this. Is that true? He had some pics they gave him of different lifts and the rancho/fabtech seemed to have the widest stance....procomp/fabtech/superlift had the least. Could you guys give me some feedback since I really have no experience in this field. Also, any good pics of your 4/6 in lifts would be great. Thanks!
Hi -
I have the Rancho 6" on my HD and it's true that they stick out from under the truck much more than a few others lifts- this is due to the spindles Rancho and others use. Procomp and Superlift stick out less but still stick out. I run 16X8 with 305's.
I have an 02 ecsb Z71 with Pro Comp 6 inch lift and 16x10 rims. Ran 315/75/16 tires with no rubbing. Shop had to trim small corner off lower valance but I would of never known if they did not tell me about it.
David
My 02 HD has a 6 inch fabtech, I have 16x10 wheels, with no backspacing problems. They stick out of the fender a little but nothing goofy or overkill. I'm running 315's. You can see pics by hitting the www button below.
edit- they did have to trim some of the bumper, but you wouldn't know unless I told you. or compared side by side
    • The amount of storage in the rear seat area is huge. You can keep all your cycle gear dry and clean back there
    • Truck in fluid changes and investigate subtle shudder at cruising speeds.  Told them it felt like my ‘14’s shudder when AFM kicked in.   Dealer #1 :  You need a new torque converter.   6 weeks later, after causing other damages to my truck, I get the truck back.  Same shudder exists. New, more violent shifts and vibrations at low speed.  After choice words and a few more weeks of waiting for them to replace my running boards supports, I move on to another Dealer.   Dealer #2:  The cruising speed shudder is DFM.  (I didn’t realize truck had it.) The TCM/ECM needs updates.  Updates will solve all vibration issues.   They perform updates, truck seemed ok in lot.  Not a mile down the road, SERVICE BRAKE PAD MONITOR. Dealer #1 stated brakes were at 4mm.   took truck back to Dealer #2, rear brakes at 2mm and less than 1mm.     New pads/rotors on rear, new pads up front.   truck seems good. Toggle through menus, brake monitor system is disabled.  Huh?  Why? Turn that sucker on : SERVICE BRAKE SYSTEM!     will not reset manually, automatically, or even after pulling negative bat cable for 30min.     Could the TCM/ECM updates the culprit?    A torque converter diagnosis for a “normal” shudder and now I’m thousands in the hole and the truck still isn’t right!  Beyond pissed.
    • Your right on. 👍🏻
    • Seats matter a lot.  I would start there - good advise here.  I had a 2018 LT Colorado before my 2026 LT Silverado, and the seats are so much better in the new one it's not even a contest.  That was one thing I always hated about the Colorado and I owned two of them spanning 10 years - but I did it so I could park in the garage mainly.  Now I have a much larger property and a huge barn so I have plenty of parking options and a full size is more useful for maintaining the property and current hobbies as well.  I wasn't evenb thinking about the seats as part of the reason for the move to the Silverado, but after two back to back 700mile road trips I am sold on the LT seats w/ leather 100%.  The other LT features are also nice - one thing I really like is the power rear window on the back window by the bed.  And the lighting in the bed is also very nice to have - I doubt that comes on the lower models.  Power tailgate - also quite useful - it's a heavy slug!  What else - I could take or leave the screen - but heated seats and steering wheel and cruise control on the steering wheel is very useable - I would never want to live without that.  Even the colorados had that.
    • I think the ship has sailed on the fuel injection type - everything is getting direct now.  Does it help with mpg?  Not really and nobody buying a HD truck really cares anyway.  But that is what it is at this point.  Piston rings is something they may well adjust over time to get them right.
