Hey everyone! I love the little bit of added rumble the muffler delete gave me on my 5.3 - 2016 Chevy Silverado 1500. I left the resonator on, as I cannot deal with drone. I am wondering if deleting the third cat will do anything to add a little more sound? Again I think I definitely want to leave the resonator on as I am very fearful of having drone.  Any advice is greatly appreciated!
You're not going to notice much of a difference in my opinion. The 3rd cat is just a mini resonator and not worth the hassle of removing.
In my experience when I put loud mufflers on a vehicle adding  small glass packs down stream would deepen the tone. And quiet it down a bit. I left it on.
Cool thank you both, guess I’ll leave it on.  What about deleting the resonator at the rear? Obviously it’s going to be louder but do you think there’ll be terrible drone? I run a Range AFM disabler so it’s V8 all the time,  so don’t have to worry about the v4 drone but wondering if if get any v8 drone?  Thanks again!
Edited by SMID333
I have a dynomax system on my truck, so it's just the dynomax muffler with no resonator and I don't have any drone.
Never did it with just a muffler delete but it's likely to be the same.
10 hours ago, pokismoki said:
if you activate enrichent function in the ECU , I would delete the 3rd cat.
First time I've ever heard anyone say that. I've been tuning my trucks for years, even running E85 and never removed the 3rd cat. Never lost performance or melted down a cat with any modification to the power enrichment settings or commanded air fuel ratio.
I've had them melt down before on stock tune, i always figure that GM designed the cats to operate under their lean tune to last the 100K warrantee on this emmissions part.  i would remove it so, at a later date one can reinstall it and it will perform to spec, by not getting cooked with excessive fuel.. its just a thought I had, i doubt anyone will do it , unless they want a higher flowing exhaust
better yet take down the factory exhaust dont cut it up,  and buy the offroad system and add your own mufflers
Edited by pokismoki
What part of the tune in lean though?
You have tuning software just like I do, it's not hard to see that they run them rich like they always have since I don't know, forever? Sure stoich was changed to 14.1 for the E10 fuels but these DI trucks run 11's AFR right from the get go, that's not lean at all.
Lean would be 13's or higher at full throttle. And there is no lean burn mode on these trucks that are from North America. In fact in many calibration files the Cat Over Temp Protection is actually richer than the commanded AFR at full throttle, the idea is that the rich air fuel ratio will lower EGT's to try and save the cats. At a certain point too much fuel would be a bad thing and start doing the opposite.
If you ask me, changing the enrichment settings to a more respectable setting of around 12.5ish AFR would make the cats lasts the longest. It's not rich and it's not lean, so best of everything. Enough fuel to keep the cats working correctly and enough fuel to keep EGT's down. Plus ignition timing is a big factor as well, too low of timing would just be sending fire balls straight into the exhaust and melting them down.
Edited by CamGTP
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 3,021 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
