I just bought a 2011 Silverado 1500 LT 5.3L z71 it has the 3.42 gears. When ever I try to take off from a low speed/rpm’s the engine hesitates and just feels like it’s being held back til it hits over 2500rpms if I try to turn slow and go up a hill it will bog all the way up the hill unless I put it in Manuel mode and drop a gear to raise my rpms, it almost feels like it’s just in to high of a gear but there is still a hesitation when taking off its like the rpm’s get stuck for a second at a certain spot then it catches another thing idk if it’s related is when I put it in gear and let off the brake it will slowly accelerate on its own. When I bought it it showed code for map sensor replaced that no change, I updated driver side valve cover for new pcv design cause after first time I drove it home when I cranked back next morning  it blew smoke and could smell oil, new cover fixed that though. Everything on live data looks good and no codes except when it hesitates/bogs the spark advance is I’ll drop to between -1 and -6.5. Thought maybe cats stopped up so I removed them with no change. Anyone that can help give insight please let me know
I have a 2013 Sierra with the 5.3 and it sometimes does that and will die if I try to accelerate. I turn it off and it starts back and runs fine. I put a new fuel cap on it, and thought that fixed it, but it didn't, I'm now suspecting that the purge valve is sometimes leaking. I had one go bad on my 2015 Cadillac SRX and it acted similar to that, and a new purge valve fixed it. I'm going to test my valve before replacing it. You can search how to test the purge valve and get great instructions. It's simple and easy to test. I do not get the purge valve code on my truck, but sometimes it says to tighten the fuel cap. I don't know if they throw a code till they're really bad. Just my thoughts, I don't like to throw money at a problem just to see if it does it. I try to troubleshoot first.
Edited by Barry Hanback
More info.
    • You have to have the last word.
    • I am sure that was quite the pass experience and not a great place to experience during the winter when the conditions are not good. I've seen video of that pass and also more detailed information and pictures about the wrecks at that one hair pin turn where tractor trailers have flown right off the cliff and I am sure from all the warning signs that you know the exact curve that was !. After all there is a reason why a song was made about Wolf Creek Pass !. By the way and I didn't realize this either when I bought my truck as its nothing I even thought of that would be programmed into the cruise control and this occurs in either the basic or the more advanced cruise that controls your distance behind a vehicle and that is the brakes going down a hill are being applied as soon as the vehicle goes a certain speed over the set cruise speed. While it certainly does force downshifts in the transmission as you found out with cruise on while going down hill, its also dragging the brakes as needed to keep the speed controlled to what the cruise was set to. For me, I find that unsettling simply because I have no concept then as to how MUCH brake input is being used a and just how hot are those brakes getting and the wear factor as well. I can see that system getting a person into trouble on long mountain grades while pulling a trailer as it would not only be standing on the brakes of the pickup without any driver input, it would also be automatically applying the trailer brakes and it could cause a run away unit by overheating the brakes. Its one thing on a shorter hill and if the driver allows it to do its thing but on a long mountain grade is where things could get so out of hand. As someone a while back on this forum said, they had someone following them at night I believe on a down grade and had the cruise set and the person behind them could see the brake lights being energized all the way down the hill. I figured when I saw your comment that you didn't know and would have no way of knowing that your truck was applying the brakes and that you would and rightfully so assume you only used the brakes when you pressed on the pedal to slow down more than the cruise set speed for the slower sharp curves. So its good knowledge to know this about the newer GM trucks, certainly when doing any descending on long mountain grades. In the future try kicking off the cruise and use the the manual mode on a pass to see what that is like as I know myself when I first experienced it I thought no way can this engine be holding me back this well and tried the same hill in manual mode and sure enough the engine was revving way up and still could not hold the trucks speed down like it could in cruise mode.    Fuel mileage, that is where a really low sleek type of car can do better at higher speeds, certainly it starts sucking fuel too but a tall pickup is pushing massive amounts of air and also allowing a lot more air under it and the tow mirrors as in elephant ears pushing through the wind  as well. Driving like grandpa is about as good as one can do when driving one of these if trying to get the best fuel economy they can. I bet these trucks would get the best mileage they can if driven on a freeway in Florida if not busy traffic at a sedate speed and that sea level elevation without hills, vastly different then Colorado !.
    • It’s over for almost 24 hours. Are you playing Eddie Haskell?
