Just bought an 82 k30 and used the 4x4 hunting today. The stick moves freely into all the positions and I can feel it engaging each area. But now the truck is driving in low range in any position. The linkages off the stick all seem fine. Really hoping I'm missing something simple and don't have to pull it out. Thanks everyone
Probably a broken shift fork inside. They are replaceable without dropping the TC but I find it easier to do dropping it
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
