I have a 2017 LTZ Z71 6.2L. I installed a fiberglass ram air hood (98 lbs) after a year the hood springs will no longer hold the hood open. Has GM updated the springs? Has anyone found better springs to install?
    zibzer2
    zibzer2
  • Who's Online   6 Members, 0 Anonymous, 806 Guests (See full list)
