Ordering new truck, have a question..
I will be ordering a new truck next week (2500HD 4X4 CC SB 8.1/Ally) :rolleyes: and wanted some opinions about rear axle ratios? I will be changing over to 285/75-16 BFG AT's soon after getting the truck and am wondering if I should go ahead and get the 4.10's or go with the better economy of the 3.73's. Do you think there will be much difference in the mileage between the two ratios??
Thanks!!
Gary
Personally, I would go with the 3.73. I wish it had been available with the 6 liter. I don't think you'll have any problem with power, and a more economical ratio wouldn't hurt.
I would have done the 3:73 if they were available for the mileage improvement unless you need the gearing for pulling a lot of weight on the hill a lot of the time.
3.73's are all the Dmax needs, it will begreat plenty for the 8.1 plus get better mileage than 4.10's. If it were a 6.0 I would say 4.10's, but with the 8.1 you want mileage, because power is not a problem.
I had a 2001 Ext cab 8.1 with the 4.10. Gas mileage was terrible (also terrible
with 3.73's) but get the 3.73 if you don't plan on towing heavy loads.
I am looking at towing a 5000 - 6000 pound boat along with a camper... but this will only be during the summer months, the rest of the time it will just be around the house..
Also, the best quote I have gotten is $38725.00, how does this sound? It is a CC LT loaded with DVD and XM. This is before rebates since I am ordering so if you include the current rebate it comes down to $36226.00...
Gary
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
