Magnaflow
I am considering replacing the stock muffler on my 2004 Chevy 1500 2wd regular cab/long bed. I want to replace the muffler only and keep the rest of the pipe the same. I like the looks of the stainless Magnaflows and Dynomaxes. I've looked on their sites for a direct replacement but they don't list one. I would like to be able to weld the new muffler in exactly like the old one. The guy at the muffler shop I visited talked about putting a shorter magnflow in and adding a short piece of pipe to make up the difference. I don't care for his idea because he would use aluminized pipe and not stainless since he doesn't carry it.
Has anyone done this before? What part number did you use? What does it sound like? Thanks!
I did exactly what you are thinking about and it droned
bad. Bad enough for me to get rid of it. Another local
shop talked me into a "Vortex" muffler that was about the
same size as the stock one and I'm happy with it. This
muffler (or the Magnaflow for that matter) is not stainless,
so it probably won't last that long. On the other hand,
it only cost $70 installed.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 692 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
