Hello everyone, I’ve got a 2016 Silverado WT trim, straight base model manual windows, small io3 stereo, etc. Recently I had electrical problems I believe since my truck would completely die on me. This all began when I was driving around all normal and after coming back to my truck and seeing that at crank it took a little bit more rather than starting up as usual. I ignore it for the night. The next morning it was dead, jumped it and immediately started right up. Later on in the day each time after cutting it off it would die almost immediately. Was very confused so went to autozone and got the battery tested. Long story short got a new battery and was told that was it. Next day was fine all day. The day after same thing happens, completely dead. I take it to a shop and guy says I must have a drain. Ok, he looks around and ends up diagnosing that the stereo is the problem. He left it unplugged and the truck starts up just fine and everything works as should, stereo is in place but unplugged. It’s been around a week like that and the truck is doing just fine. One thing, it has no chime, seatbelt alarm, or even turn signal sound, is this because the radio is unplugged ? Anywho I was simply wanting to know if I could go and just buy another io3 screen and just plug it in and use that. I’m assuming my screen must have a short or a problem, since after it has been unplugged the truck is just fine.
is just the screen unplugged or is the radio unplugged. with having no sounds anymore it probably the radio is unplugged. the screen is just a display of what the radio is set at and i doubt the screen is the problem. you can replace the radio but it will be vin locked unless you buy a new one from gm and have it programmed
I’ll take a look at It tomorrow and see what isn’t plugged up exactly. Is the radio part the “HMI” ?I’ve seen a lot of things about that but never about the radio part. Or do you know where that would be since the screen is sorta separate? Thanks man.
hey man, so instead of taking everything apart and what not I simply started off with checking out the radio fuse. Which was not in place. I was a bit confused so I put in the spare one from the driver side fuse panel and everything came on stereo, sound, chime. I’m assuming the mechanic just removed that so it won’t be on but I am worried that if I put it back in now will it kill my truck again and I don’t want to be left stranded. What you thinking I should do?
    B07
    B07
  • Who's Online   0 Members, 0 Anonymous, 839 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
