How does everyone feel about the Vader chrome grille?  I liked it at first but a couple issues with it IMO
1.  It doesn't match the rest of the accents like it always has
2.  It tones the truck down and gets rid of that "king of the road look"
im looking to replace with chrome anyone else?
I'm looking to buy an Ultimate just for that reason. I like chrome but to me the chrome grill is too much. I'll get a dark color and it won't stand out like on a silver or white truck. I'll also look into wrapping the lower grill in a satin black.
This.  I hate that it doesn't match the lower grill insert, which is bright chrome.  Makes no sense.  On the 2024 HD Ultimate, they made the lower insert vader chrome to match.  As for the mirror caps, door handles, etc, that doesn't matter to me as much.
That and I wish the interior didn't have to be had with brown seats, not a fan.
I did some checking and there is a black chrome vinyl wrap. So that's what I'd do to the lower grill.
I suppose you could wrap all the chrome around the truck with it.
Love the interior. Very similar to a F150 King Ranch I had.
I've thought about doing the same but would like to see how the chrome looks first.
i love the interior - such a step up from prior denalis.
Get what you want and I'll trade ya!
Edited by Paul Ventimiglia
  • 7 months later...
I know this is an older thread, but I actually just bought a Denali and want the vader chrome, so if you're wanting to trade I'm down.
Check your messages
    • They’re not the same wiz as 10-15 years ago.  QC has fallen pretty hard.  The XP line was never good though in the first place.    https://bobistheoilguy.com/forums/threads/wix-filter-rusted-through.386492/post-6991372   https://bobistheoilguy.com/forums/threads/i-ve-used-my-last-wix-filter.27299/   https://bobistheoilguy.com/forums/threads/looking-for-a-better-replacement-for-wix-51258.403977/   https://bobistheoilguy.com/forums/threads/convince-me-in-using-the-purolator-boss.401537/post-7420147   the forums are littered with posts and examples of not great wix filters the last couple years
