Oil Change lite on 03 Pickups
My Oil change light never comes on. I always change oil every 5000K, and it has never come on so far? When do you guys change oil and when does your light come on?
Thanks
Mine comes on between 6500 and 10,000, depending on the time of the year, what kind of driving I'm having to do for several weeks (some weeks are mainly low speed, some weeks are mainly freeway).
The 3,000 mile mantra is DEAD. No more. GM and other manufacturers are recommending to use the oil life monitor.
Your manual recommends using the monitor. There are a lot of flame wars on the other boards about this. So, rather than my stepping in this old issue, here is a link to the General Motors site that explains their recommendation:
http://service.gm.com/gmtechlink/images/is...03e.html#story1
Mine's come on 1 time in the year I've owned this truck. And it was right around the time it was due for an oil change. I change my oil approx every 6,000 miles; I drive 5 days/week on the highway and mixed driving on the weekend.
I did my initial oil change at 600 miles to a cheap 5W-30 and a PF-59 to clean the build shavings out; reset the OCI. At 1,200 miles, changed again to Mobil 1 0W-30 and PF-59; reset OCI.
Generally, from that time on, I've only changed the oil (Pan drain) twice a year: Mobil 1 0W-30 winter and Mobil 1 10W-30 summer. I change the filter when the Message Center scrolls CHANGE ENGINE OIL.
FWIW: the inside of my oil filler cap is SPOTLESS. Clean as a whistle. I average about 4,200 miles per quart running Mobil 1 0W-30 and 6,800 miles per quart running Mobil 1 10W-30.
If I lived in a more "moderate" climate (Warmer than 0 F most of the year) I'd run Mobil Delvac 1 5W-40 all year round.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
