I had to take I truck to the GM dealership my OnStar was failing to connect they had it for about five days they said they had to order a brand-new OnStar module and it's going to take a month and 1/2 to 2 months to get. On December 20, 2020 I totaled my brand-new 2020 Chevrolet Silverado I'm a diabetic and I blacked out because of a diabetic low they airbags didn't deploy and I was way down a hill I live in Northern California OnStar signaled I was in an accident and a Caltrans snowplow driver came and found me my budget was 27 I would've died if no one had found me those no evidence of an accident site no one could see my vehicle from the road so it's important I have my OnStar working. After the accident the care of my diabetes was taken over by an intro endocrinologist in now I have a Dexcom meter that alerts me of highs and lows. I wonder if anyone else has had experience with her OnStar not connecting?
    Fishboat
    Fishboat
  • Who's Online   4 Members, 0 Anonymous, 629 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
