I have a 2021 Sierra 1500 SLT with just over 60,000 miles on it. Recently the truck started displaying the backup camera on the infotainment center whenever the brakes were applied. I did what some of the other forums suggested and removed the taillights and put dielectric grease on the connectors. While I was doing this I found that the passenger taillight had water in the housing and there was a small amount of corrosion on one of the pins in the connector. I dried everything out thoroughly and applied the dielectric grease but I am still getting the camera on the display when braking. Any ideas?
Sounds like something has shorted out, if you ever find out what its causing it, I would love to know. Maybe I can make a button to turn the camera on demand. If it is 2021, is it still under base warranty? Would you be able to request the dealer to document what is causing the camera to come up?
    Policeoff01
    Policeoff01
  • Who's Online   5 Members, 1 Anonymous, 788 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
