I do not see an L92 specific location in the Electrical Manual.  Does anyone know where it is located?
Also does anyone know where and what the SA550 ground is?
I am trying to fix a weak ground to the RUN / CRANK fuse.  SA550 is notated in this diagram.  Not sure what it is.
Thanks for your advice.
The one zone 5 in the first picture is the ground on the back of the drivers side cylinder head. There is usually always one there.
And I think there is a ground that runs from the cross member under the engine to the engine block itself as well.
Edited by CamGTP
Are you talking about the RUN/CRANK relay and not fuse?  There is no run/crank fuse.  Run/crank relay circuits follow out to ground G102.  G102 is located on the driver's side of the engine block, just under cylinder # 1 below the exhaust manifold (driver's side front cylinder).
TBH, I wouldn't be surprised if you are looking at a bad underhood fuse block and the RUN/CRANK bus internally is corroded or shorted out.  UBECs are VERY common on 07-13 trucks.
Edited by newdude
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 1,055 Guests (See full list)
