Hello Team
I just wanted to introduce myself and my new Silverado to everyone.  2023 1500 LTZ 6.2 L
I also posted a 5.7 second 0-60 time using Draggy.  The best 0-60 I could muster with my 2015 GMC Sierra 2500 LML was 7.3 seconds.  This 6.2L rips!
 What 0-60 times are others getting?
 Take care,
 Steve
Edited by Rhino Linings
Not too shabby for a 6k lb brick.
Went from a 17 Sierra with the 6.2L and 8 speed to a 22 Sierra with 6.2L and the 10 speed.  The newer truck does seem to be quicker.  The 17 had a bit of a detent on the throttle pedal about 3/4 throttle that you had to push through to "wake up" the engine, but the new truck doesn't and every once in a while it surprises me.
  • 5 months later...
My best 0-60 on the draggy is 5.11.   Launching in 4wd high in tow haul mode.  ‘21 RST CCSB 6.2  3.23 gears. 20” wheels.
Edited by SILVER SLED
On 11/18/2023 at 9:46 PM, typhoon186 said:
Was that just launching in 2 wheel drive?   Traction control on or off?
That was in 4 Auto being brake torqued to about 2,800 rpm before dropping the hammer.
I'm curious how the tow/haul mode affect 0-60 time and 1/4 mile.  Are the shift points a little higer?
I haven’t tried enough times to verify anything about shift firmness or shift points.  But shift points seemed the same.  I’ve tried tow haul mode vs sport mode back to back and tow haul was quicker.
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,360 Guests (See full list)
    • I have 2 choices.
