I notice that on the upfitter aux switch panel harness (the one that runs along the cowl in the engine compartment has some wireclip that attach with the existing panel clips.
I'm not installing the aux switches, but I'll be installing some wiring along the same path for my powersteps.
Does anyone now the part number? It comes as part of 84794790.
thanks
  • 3 months later...
The breakdown of CABLE ASM-BAT POS CBL EXTN P/N 84794790 only shows RETAINER-BAT POS CBL P/N 11589290 QTY 4 which looks like a push-pin, doesn't appear to be the part in question
The Math Data for CABLE ASM-BAT POS CBL EXTN P/N 84794790 shows 84396607 CLIP-WRG HARN is the part in question, but it's Not Serviced
