A/C Vent "open/closed" ???
On my truck (2001 silverado), if I turn off the A/C & open
the vent (outside air), the compressor is off.
If I switch the vent to recirculate, even if the A/C is off, my
compressor runs as if its on & puts out cold air. Obviously, I dont
want the compressor to run if the A/C is off!!
Do all of the GM trucks (circa 2001) do this???
TIA............Cam
When you recirculate vehicle air you have a greater chance of the inside of the vehicle fogging up, hence the compressor runs to dry the air, If you do not want the A/C on when the A/C switch is off, you cannot recirulate inside air, you need to bring in outside air. A perfect example is my 90 Nissan. When in recirc mode the windshied fogs up. Cannot use that setting unless the a/c is on and you want to Recirc. the inside air instead of bringing in outside summer humidity into the mix.
When you recirculate vehicle air you have a greater chance of the inside of the vehicle fogging up, hence the compressor runs to dry the air, ..................
Probably 350 days of the year (or more), fogging
would not be a problem for me in Houston.
I just want to be able to stop outside air from coming
in when I want to.
ZX,
Welcome to the board. What part of Houston are you in? I'm down in the League City area. Are you sick of Super Bowl stuff yet??
ZX,
Hey Mike,
Thanks.... :nono:
I am actually in Spring.
Guess whose windows fogged up on the way home yesterday...lmao!
Still, I just hit defrost for a sec & all is well. On the same note, how come
the dang defroster wont let you put it on inside air, only recirc??? :jester:
You cant put it on vent & inside only without the compressor running, & you cant put it on defrost & inside only, yet the compressor runs when on defrost!! :crackup:
how come
Recirc = inside air.
Recirc off means it pulls the air from outside.
Defrost runs the compressor because you'll have increased frosting if you try to defrost with moist air so the compressor dries it first.
how come
the dang defroster wont let you put it on inside air, only recirc??? :crackup:
Sorry, I said it backwards, the defroster only works
on the fresh air mode, not the recirculate mode.
I can understand the compressor running on defrost, by why
wont it let you put it on recirculate, only fresh air?
thanks for all the comments, guys.....
