change battery
This may sound foolish , but i would like to change the battery before it dies , and i want to do it myself . My question is can I do it without loosing the codes for Radio and all ? Thanks in advance :crackup:
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
