Installed my Magnaflow catback..
I got #15778 side-exit 3 inch with 4inch tip with a 22" muffler for my 5.3L ECSB '04 truck. Some people had said the 22" muffler is too quiet, well it certainly isn't with the 3 inch plumbing.
It sounds good especially winding it out. There is a bit of drone around 2000rpm, though I had that with the stock system too. It has a very nice, deep tone and I'm happy with the sound and quality of the system. The muffler is mirror finish and the 4 inch tip with engraved 'Magnaflow' looks sweet sticking out the side.
Getting the stock exhaust out without cutting it was a bitch as I only had ramps and a jack to get the truck up high enough to get the exhaust out clearing the rear axle. That said it only took 2 hours start to finish.
I got the system for $377 shipped from http://www.fle-online.com/
Service was excellent and they shipped the system first thing Monday as I ordered on a Saturday. It arrived Thursday morning.
I don't have pictures or videos because I don't have a digital video camera and my digital still camera has a dead battery.
I am happy your magnaflow went together better than my old Borla system. I have a magnaflow on my race car (1991 Eagle Talon) and its excellent. Really quality stuff. :crackup:
Was installation hard? What was involved in doing so?
Did you go to OU? If so, I can't help you. :jester:
1. I backed the truck up on some small ramps I have to raise the rear-end.
2. I then crawled underneath and unbolted two bolts that connected, for lack of better description, the cat-pipe from the catback-pipe. You'll see them.
3. Then, there are three rubber things that keep the stock exhaust (and the new exhaust) elevated, you just slide the exhaust hangers out of those rubber things. NOTE: Spraying a little oil will help A LOT to slide the hangers on and off.
4. There is a small, black brace underneath that I removed. One bolt and slide it off to the slide to help facilitate the removal of the exhaust in one piece.
5. Then I had to use a jack and a few jackstands on the front of the truck to get enough elevation to get the back part of the stock exhaust around the leaf springs and off in one piece. It's long, so rotating the stock exhaust around to get the back curve around the leaf spring requires a little bit of work.
6. After the stock exhaust is out, bolting the Magnaflow on was an piece of cake. Use the stock rubber hangers, the Magnaflow is in 3 pieces, so bolting it up front to back is very easy.
Were I to do it again, it would probably take one hour start to finish, but I had to figure out how to work the stock exhaust out with limited space underneath the truck. Having it on a lift would help A LOT, probably a 30 minute job at that point.
It was worth it. :crackup:
Did you go to OU? If so, I can't help you. :nono:
Ouch!!!
:crackup:
I'm glad you like your exhaust, congrats. :jester:
LOL, no I'm not an OU Student, just grew up in an OU Football house. I'll be a University of Houston student next fall.
Thanks for the description. I wasn't sure about welding or anything.
No welding at all, it's a full bolt-on system. :thumbs:
Wingnut,
I'm not the biggest fan of tu either. :wtf: Though, my g/f did go there. House divided in Dallas. :wtf::lol:
    Zinister101
    Zinister101
  • Who's Online   5 Members, 1 Anonymous, 536 Guests (See full list)
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
