Factory Navigation
Hi I am new here, but have a SilveradoSS. I would like to upgrade the factory bose to the factory navigation, moving the changer into the center console. Anyone try this? Is it even possible? Anyone have the part numbers? for the head unit, cd changer, antenna?
thanks for your time
joe
There is a guy selling the under dash harness with navigation harness on EBAY. He stated that he bought it for his Sierra, but could not get the harness to fit. I imagine that it would cost you a small fortune to swap over when you could just go aftermarket and get something that you really like.
Nick
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
