2020 Silverado active shutter communication lost. Causes the Engine light to come on and won't allow for remote start. Had this repaired once already at the dealer. Thus is getting stupid. Why does the shutter control module keep shorting out? I'm not paying another $200.00 for another shutter assembly. Help!!
Check the wiring for the shutter.  There is a couple spots where they rub through where they pass through the front support.  Lots of sharp edges.  Wiring I think runs down the driver's side.
Could also be a wiring issue in the engine harness which these trucks are known for.
If that shutter was replaced recently, the part itself would still be under warranty for 2 years/unlimited miles from its install date, even if you are out of bumper to bumper.
Edited by newdude
There was a recall for the wiring on certain trucks as well due to improper routing of the shutter wiring causing it to rub through and short out.
Here's the article I remembered:  https://gmauthority.com/blog/2022/07/chevy-silverado-gets-service-update-for-aero-shutter-wiring-harness-issue/
Affected vehicles:
  • 2022 Chevy Silverado 1500
  • 2022 Chevy Silverado 1500 Limited
Number of affected vehicles: GM did not specify how many vehicles are affected by this particular problem.
Owners should: GM will likely notify owners of affected vehicles and instruct them to make an appointment with their dealer. Owners that are unsure whether or not their vehicle is affected by this service bulletin can reach out to GM directly with any questions or concerns they may have using the Service Update number and contact information included below.
Contacts:
  • Service Update number: N222365750
  • Chevrolet Customer Service: 1-800-222-1020
    tblt44
    tblt44
  • Who's Online   1 Member, 0 Anonymous, 500 Guests (See full list)
