First off im not an audiophile.
I'm 61 , But I like to Rock.
The stock bose setup is weak as we all know.
My goal is to keep this upgrade under $1500 and ease of install.
Of course with bose so all ohms are different on each speaker so I'm trying to stay close.
Dash is 3.3 ohms
Fr door is 1.7 ohms
R door is 3.4 ohms
And the sub is 1 ohm.
I'm not adding an amp but I am going with the GM Kicker setup that goes under the back seat.
I will be adding Hushmat on the insides of the doors also.
This will be a total DIY install  so I'm not looking for a competition setup but something that sounds way better than stock and is easy to install.
I don't like all the complex bs with speakers and amps.
Front Door- Memphis PRXS69
https://www.sonicelectronix.com/item-186811-Memphis-PRXS69.html
Rear door JBL Stadium 62F
https://www.crutchfield.com/p_109STAD62F/JBL-Stadium-62F.html
Dash JBL Stadium 192T
https://www.crutchfield.com/p_109STAD192/JBL-Stadium-192T.html
Edited by dieselfan1
  • 1 month later...
You need a midrange tweeter in the dash. Did u get everything installed? If yes...how does it perform?
I haven't installed anything yet but I just ordered the GM Kicker setup and got it in three days.
You are correct.  The phone uses these speakers and it would sound like crap.
I didn't realize this until after I ordered them .
I got some Audio Control
2 3/4" midrange to use instead. These are 3 ohms. Close to the 3.3 ohm stock bose.
A question i have is I'm wondering if I can splice into the dash wires and mount the tweeters in the A pillar like the older Chevys and have a midrange 2 3/4" and the 1" tweeter run off the same wires.
I also didn't want run a bunch of different brands of speakers but I wanted the ohms to be as close to possible.
I probably won't get this stuff installed until after Christmas so I will post when I'm done.
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 877 Guests (See full list)
