I hope this message finds its way to GM personnel.  I would cancel my two GM Marcus Card accounts in a heartbeat if it wasn't for loosing my accumulated points/cash. Web services and support are woefully lacking.  Marcus is the worst possible choice for a company I otherwise love.
Edited by J Voyt
  • 2 years later...
Thought it was about time for an update on the GM Card since Barclays bank took over from Goldman-Sachs, or at least my experience. The Barclays website is relatively easy to navigate and provides much more information, you can even get your FICO score with one click. It even tells you how many lifetime points you have redeemed, in my case I've saved over 11K on 4 cars since the '90's. I think Barclays must have negotiated with GM so that customers now can use points for service, parts, and accessories rather than just use the points on a new car purchase or why would an older couple such as my wife and I that have likely bought their last new car use their card, we would just use another rewards card. Took my wife's '24 Blazer in today for an oil and filter change and tire rotation. After I asked for my old geezer discount, I whipped out my Barclays GM card and said I'd like to use my GM card points to pay for my service today. I suspect I might have been the first person to do this at this particular Chevrolet dealership as it took both my service advisor and the service manager and a lot of keyboard clicks to figure it out, but in the end they did. The points wouldn't cover sales tax, shop supplies and a $2 regulatory compliance fee so in the end I walked out after the service about $19 out of pocket and $111 in points. As it stands now I should be able to get about 3 more oil and filter changes unless I have to buy a new battery right after the B to B warranty expires this next October. It's always a balancing act between the GM Card and my airline miles card but I'm liking these $19 dealer oil and filter changes.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 1,769 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
