I've got a 2018 1500 5.3L silverado. My H/VAC systems all work great, with one exception. When I select defrost mode, I notice I still hear the fan blowing, yet no airflow coming from my defrost vents. When this is happening, no air is coming from any other vents either (which is to be expected). What do I check? Is there any useful guides or viedeos out there to help? thanks in advance.
Maybe it needs a recalibration of the HVAC system? Take a look at this post for some info but there are other threads on this as well.
I will give this a try and report back. Many thanks
  • 9 months later...
Reviving this thread as colder weather is apporaching again... I tried re-calibrating the system using the method above but no luck. Still no airflow when I go to defrost mode. Would this be a problem with the blend door actuator?
Unfortunately it might be. There are folks here much more knowledgeable on these kind of things so hopefully they will respond shortly.
After doing some more research I think my probelm is with this part: https://www.amazon.com/ACDelco-15-74349-Original-Equipment-Conditioning/dp/B00S0JJM8O
The mode actuator, not the blend actuator. If figure its the mode actuator because all my temp controls work fine, it's just going to defrost mode that prduces no airflow out of any vents besides the footbox. Looks like it could be a major pita to get to. I will start with replacing this and report back if my problem is fixed.
    • I went to order some PF63 oil filters from an on line GM parts source, and the blue PF63 oil filters seem to be getting phased out. They show the new part number as 19363567, which is a black colored AC Delco Silver product apparently marked PF63A. Some sites show a part number 12693541, which is a black colored AC Delco Ultragard Gold filter marked UPF63R.    I assume the UPF63R is the better one, but I’d be happy if I could just get blue PF63 filters I’ve been using.    Can anyone explain what is going on with the filter part number changes and any actual design changes?  Any other advice on buying OEM filters right now?  Thanks
    • thanks for coming back and posting what the fix turned out to be.
    • Only TAN I have for the product was at 5K in service miles and it was 2.71
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Will be attempting this sometime shortly and will likely make a youtube video out of it.   Note: please disregard fuse sizes. Main fuse will likely be 25A, all mini bus fuses will likely be 10-15A.   Here is my parts list: GM 84347199 - TC, Cargo Light, Exhaust Brake (useless to me unless I find a means to reconfigure), Aux 1 - 4. 12V 6 Way Pre-Wired Fuse Relay Box Kit with 4 x 40A 4-Pin Relays (link below - some mods required to make negative trigger)            https://www.amazon.ca/dp/B0F4KCS43B?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 Various wire sizes (12 AWG - red and black, 14 AWG, 16 AWG multi-colored bundle) Wire termination leads for X61A-X1 (unknown at this time) Crimp connectors/Soldering Gun Heat Shrink Split Wire Loom To be continued...    Cheers
