intake systems? worth it?
I havent heard of them before. Guess I will have to check 'em out. Id look into Ultimate Performance & Design and maybe AEM's Brute Force Intakes. I have a UPD (NSV) and to date Im veyr pleased with it. Had a bit more umph on top end. Maybe slightly better acceleration. Intake noise is considerably louder too. I cant remember how much I picked mine up for. But I got it through a group purchase on LS1Tech long time ago. ProCold makes a pretty cool setup for the NBS Silverados. It is somewhat like the K&N FIPK but the ProCold puts the filter element down under where the stock airbox mounts. Keeping the filter from beng soaked by engine heat. Idont know of too many people that have them. Some have tried them with great results.
ProCold
AEM Intakes
thanks jared, i'll check the sites
i have a friend that insulated the entire stock intake with the material that air conditition guys use on the ducts and he says it helped a bunch only draw back it looks a little funky!
peter d
