I crawled under my truck today and found there's some leaks along the front diff line. I'm not sure what it is. Can anyone please help me identify what it is. It's the small yellow part in the picture. The front diff itself is also kind of wet around the fill plug and drain plug area  but no drip. Just like damp wet.
2014 Sierra 1500 SLT 4WD
Thank you!
The yellow part looks to be the front diff. locking mechanism. From what I see, there's a very small amount of "seepage & not a leak so to speak. I think you're good.
I bet if you cleaned it all off with some degreaser it would take years to look damp again.
I proceed to change the front diff fluid. I put in Mobil Delvac 1 Synthetic 75w90 oil. The front diff is now whining. Is synthetic oil not compatible with it? I read somewhere that a vent connector needs to be replaced if using synthetic oil. It was for older model though so not sure if the 2014 model is the same?
Edited by Neil G
Synthetic GL5 gear oil is fine for front & rear diff. How many miles on it & did you fill it up?
It has 113+ kilometers (I'm in Canada so it km). It's filled I think. I opened the fill plug again and it started dripping oil. I noticed when I opened the fill plug, there was a Sssshhhhhhhh sound like air coming out from the fill plug. Could it be the vent is clogged or maybe it's over filled?
Sounds like tge vent tube is bad somewhere. Shouldn't have pressure like you mentioned. That will make it leak.
Thank you!
I'll go and check the vent tube. I'll drain some more oil as well, like open the fill plug and let it drain until it stops.
The vent tube should be on the drivers side under the hood.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,165 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
