I've been looking around and saw some info on the speakers in Sierras and Silverados, but not necessarily specific to the Denali Ultimate.  I know what size speakers go on the rear doors, front doors, and dash.  What size speakers are on the door pillars?  Is there a center speaker?  What size is that?  Any others?  I saw something that said the Denali Ultimate has 12 speakers.  I don't count that many grills...
  • 2 months later...
@reese what speakers did you eventually go with for the dash and center in the denali ultimate?  We really didn't get much for the supposed premium 12 speaker setup...still sounds like an AM radio wrapped in a wet towel.  Thanks
@shewstring  I got the following:
Helix CI3 W200FM-S2 for the front doors.  8-inch midbass/woofer.
Helix CI3 K165.2FM-S2 component set for the rear doors.  6.5 inch/1-inch tweeter component set
Helix  T20FM-T1 1-inch tweeter for the pillars
Blam LFR52 2-inch driver for the 3 dash speakers.
Vastly improved sound but not enough of it, despite them testing and matching the impedance all around.  Therefore, I will be getting a Helix V12 12-channel amp next.
I also have the Kicker 10-inch subwoofer.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
