This is more of a PSA in case it happens to someone else.
I had new struts installed in the front 2 years ago, no problems.  Last year, I switched out the rear air shocks with no issues.  Very intermittently, I'll get a "service suspension" alert on the driver display.  I don't notice a change in handling or ride so never paid much attention.
Last week, I was traveling back from Keystone, CO, and the "service suspension" message came on.  I cleared the message and continued on.  Once out of the mountains, I attempted to set the cruise control but it wouldn't work.  All other steering wheel controls worked including cruise on/off, it just wouldn't set a speed.  Next, I was attempting a pass and around 85 MPH, the truck stopped accelerating regardless of pedal position.  I thought my transmission was going out (204k miles) but kept driving because the family was asleep and no CEL.  Truck would accelerate fine from 50-80 but at 85 it would just stop.  Well, doing some googling led to a discussion about the "service suspension" error triggering a mild limp mode where speed is limited to 85.  Stopped for gas, restarted the engine, and no problems after that and no service suspension message again.
Hope this helps someone.
Did you ever find out what the issue was? Was the struts after market? I'm experiencing the same exact issue with my 2019 Suburban
  • 3 months later...
I put new shocks on the rear again a few weeks ago (65k miles on them and getting rough) and noticed one of the electrical connections wasn't "clicked" in.  I had trouble getting the new one to click in also until I spray the rubber with lubricant and it slid right it.  Haven't had the issue since then.  Also, the message/limiter would reset with turning the car off/on again.
BTW, the struts were put in by a shop so I'm not sure if it was OEM or after-market.
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,395 Guests (See full list)
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
