2 hours ago, fertech said:
I have a Silverado 1500 5.3L 2020 and wanted to know if anyone know where is the pcv located,
also do i need to replace the whole valve cover or just the pcv?
PCV or Positive Crankcase Ventilation system is that, a whole "system" of plumbing, baffles and if equipped, check valves.
What piece or portion of the PCV system are you inquiring about?  There is a foul air hose, fresh air hose, both valve covers have PCV oil/air separator baffles (those domes between the coil packs), and then the driver's side valve cover has a built in metered orifice where the foul air hose attaches to.
Edited by newdude
PCV Valve, the reason is cause one day my truck dashboard said low oil add oil, so when i check it had no oil at all, i added oil, and a few days had no oil again.
i do have some code:
There is no separate valve. It's built into the valve cover. Neither of those codes have anything to do with no oil. PCV is NOT going to be the issue if you lost all oil in a few days.
Those codes have nothing to do with the engine.
These engines don't have a "pcv valve", just that metered orifice in the driver's cover that the PCV foul air hose attaches to.
Your oil loss is either from leaks or from consumption.  Leaks most likely being oil cooler lines, consumption being carboned up stuck piston rings.
the reason you are loosing a lot of oil can be from yes the pcv. but thats not the big problem. the pcv gets plugged allowing too much crankcase pressure. where does it go? the path with least resistance, rear main seal. i just did mine a day or so ago and i noticed on my pcv there was alot of dirt buildup around it. which if you oil will collect any dust and will tell you if you have a leak. i had the same issue oil low sign came on, filled it. next day same thing but i smelled burnin oil. underside of truck was covered and it was coming from bellhousing. indicating rear main. hope this helps
    smandy
    smandy
  • Who's Online   5 Members, 1 Anonymous, 778 Guests (See full list)
    • She's laughing all the way to the bank.
    • There's a new PI on 2023-2026 L3B shudder.  Possible faulty front oxygen sensor.   Dealer can pull up PIP6060A and give it a read.
    • Also here's the drive cycle for a 2021 Yukon with V8.  DO NOT USE THE CRUISE CONTROL WHEN RUNNING DRIVE CYCLE!!!!!:   Warning: Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage. Note: You have completed this procedure when all parameters display Complete. Short stops for traffic will not affect the procedure. Note: Do NOT use cruise control during this procedure. Ignition/Vehicle » Off — For greater than 8 h Verify the scan tool parameter: Cold Start-Up = Yes If not the specified state Ignition/Vehicle » Off — For greater than 8 h & Repeat this step If the specified state Ignition » On / Vehicle » In Service Mode — For 1 min Engine » Idling — For 2 min Drive the vehicle while maintaining the following conditions for 20 min: Part Throttle Vehicle Speed = 24 to 97 km/h (15 to 60 MPH) Safely stop the vehicle Operate the engine/vehicle within the following conditions: Accelerate the vehicle to 64 km/h (40 MPH) Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 10% and 13% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 13% and 16% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 16% and 19% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 19% and 22% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 22% and 25% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Maintain steady state throttle at 89 km/h (55 MPH) — For 10 min Safely stop the vehicle
    • About the only GM that compares well with its competitors through the small to midsize vehicles is the Trax. I would like nothing better to just drive GMs. My wife in a Cadillac me in a Chevy minivan and Colorado. Part of my day is comprised of reading and watching comparisons of automobile. I could buy a car today. I’m back to research the next.
    • Do you have any DFM defeat devices like the Range modules?
